hd 6 crawler
tyson85 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tyson85 Quote  Post ReplyReply Direct Link To This Post Topic: hd 6 crawler
    Posted: 20 Aug 2014 at 11:57pm
I read in another post that the 24v starter requires two 24v batteries is that a type"o" or is there two 24v batteries hooked in parallel
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2014 at 4:28am
24V can be two 12v batteries in series or four 6V in series, I have two group 31 12V batteries in my 7G they have a cross strap at the + of one battery to the - of the other making one large 24V battery. Mine is + ground, the - cable of one battery goes to the starter solenoid and the + of the other battery goes to ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tyson85 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2014 at 5:22am
Right and I did hook two twelve volt batteries in series to bench test the starter the shaft turned about a 1/4 rotation both batteries were fully charged the post I read on this Web site said it was a 24 volt starter powered by 2 24 volt batteries never heard   of a system being hooked up like this? Anybody have a manual that confirms this? I just bought this machine a week ago don't
Know much about it HD 6 is about the only thing I could make out on the data plate. The blade set up looks like an HD 5 any ideas on a possible year? New to a/c any info would be helpful thank you!
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2014 at 5:48am
my 1965 hd6b uses 2 12volt batteries hooked in series
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2014 at 8:07am
All the ones I had had 2 12 volt batteries. I might have a starter left over for 1 if you need it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tyson85 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2014 at 12:57pm
Yep looks like I'm gonna need a starter thank you gentlemen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tyson85 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2014 at 1:02pm
