UNDERSZVE LEROI MAIN BEARINGS NEEDED
Unstylish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Topic: UNDERSZVE LEROI MAIN BEARINGS NEEDED
    Posted: 13 Mar 2010 at 7:39am
I need a complete set (OR JUST THE THRUST MAINS) for a Leroi 201-226 block, in undersize. USED IS FINE, even if they have some wear. Would LOVE to find some .020 unders, so check your shelves. And no, I dont want them out of your WC-WD etc :)
THANKS A MILLION FOR LOOKING....Unstylish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 7:41am
WHOOPS, I meant UNDERSIZE! I was trying to balance the computer in my lap...
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 7:45am
good thing about this new forum you can go back to your post under Post Options, click on it and an extra choice appears on your owns posts ... Edit Post.    Lets you change about everything.  A great addition for me.
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 8:08am
Whats wrong with wd bearings?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 8:08am
Try this site.     http://www.normsactractors.com/
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 1:41pm
I want Leroi ones. Chalmers were different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 4:32pm
C'mon SOMEONE has to have a set SOMEWHERE!? :)
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2010 at 7:12pm
hmm i think ive seen that avatar pic somewhere before. I use to have the part numbers for the lerio bearings . I will have to search my closet(library) . anyone who did that crank work can make the allis bearings work though.  you selling any more cams to people that shouldnt own a wrench less a tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 8:50pm
haha, no, I am down to my last one, which I am keeping for myself if I ever start to expiriment a little. I was kinda thinking about your 4.1875 pistons...Anyway, I know of a guy up here who machined a Leroi block to a WD 45 crank. BUT I have Leroi crank AND Block. The crank needs to be turned, and guess what, no bearing avail. JUST the thrust is different. I REALLY want to put a little offset/4.1875 motor together with a Leroi cam..etc and tweak it a bit. BUT, no bearings. I hadve numbers, but there is no stock left..
I figured youd recognize the pic. Thats about the only reason I put it up. :)
I see the guy on YT Never DID tell us if he got his motor in time. If he did, I didnt see it.
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 9:03pm
I have a 226 Lerio off a pull type combine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2010 at 9:29pm
Want to check bearing sizes for me..? :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 8:28am
Its been a while and work has trained me to write everything down and remember nothing. But if I am remembering and not reading writings isnt the lerio blocks thrust on the center bearing like a d17 .  the guy you sold the cam to . i do not know his name but he posted later he had it running and if i or you had anything to say privately email him so I did. the email said good job i knew you could do it . he did not reply back i took it that he did not want to admit it was his doings or lack of causing his promblems .
Edited by mlpankey - 17 Mar 2010 at 8:36am
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 8:53am
I have a Clevit Thrust here. OD= 2.7095, ID=2.4975, width between thrust tabs=1.670.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 12:42pm
Whats the part number? FM number is 612M.
Edited by Unstylish - 17 Mar 2010 at 12:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 2:57pm
Monmouth # MB 1671P, Monmouth was a division of Clevite Corp. AC D-17 Main Bearing. Check your block/Crank to see if the #'s work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 6:25pm
But a d17 main bearing would have a 3 inch journal, and an early d17 bearing would have the same journal size as a leroi, but also is the same as a wd45, which still wont fit....I think....I have to do some digging..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 7:39pm
Well, the ID I posted is about 2 1/2 inches not even close to 3 inches. Put the Main bearing cap on the block and measure the ID of the hole you have there, also check the width of the cap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 8:06pm
yes  i missed that up .i warned about going off memory . anyways  clevite  no. are locating lug on flange 1 bearing ms-321b  2@3 mb367  notched dowel pin on flanged no1 bearing ms-209b  1mb-366(f) 2@3 mb-367  bearing shim kit sm-119s
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 10:21pm
nothing else has seemed to work..anyone else have any? EVEN A CHEAP JUNK MOTOR!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 10:39am
Check with Merle Abott he likes running the lerio stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 7:21am
Who's he? BTW, I dont hear and motor running yet!! ...It would be nice to see some video with good sound when you do. Oh yeah, check this out, I got my 327 rotating assembly balanced 2 weeks ago. I wasnt going to, but sprung for it anyway. The crank was sooo far out of balance that they actually had to weld a giant piece of heavy metal to the front throw. The guys (who have balanced numerous tractor motors for me in the past) said that it would have shaken itself to death....hmmmm..interesting..
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 8:06am
They are always out of balance . the lerio crank has enough counterweight to add weight to balance . the allis cranks you add weight to the front pulley and remove weight from the flywheel to balnce. You guys will eventually learn that I just aint full of bull snott one of these days. HAHA lol.  I will have to see if i still have Merels email address. We are slow on the engine running maybe by the end of next month it will make smoke. hopefully .
Edited by mlpankey - 29 May 2010 at 8:07am
