flywheel
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: flywheel
    Posted: 13 Aug 2014 at 10:07pm
looking for an adaptor to put big block chevy fly wheel on a 426 or a steel 426 flywheel with smaller diamiator Iits going in a 190
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2014 at 10:15pm
Not sure but my guess I you will have to find a machine shop and have made what it is you need. Option #2 would be to have a flywheel made specific to your application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 6:00am
Yea was looking to see if any body had somthing I no iam not the first to put a 426 in a 190 thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 8:40am
You are correct. Haney's from Athens, Alabama have had a 426 in a 180 for a while now. It is now a component chassis but I think it was a 180 driveline when it was first installed. There was also someone who just posted a video from a 200 with a 426 installed. Talked with either of those folks.
How fast do you need to go? What class / rules will you be running?
Edited by O.P.S. Heads - 14 Aug 2014 at 9:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 2:38pm
3500 rpm 12 mph cut tires post 1962 my safetyis higher than tthere's 17 mph open class
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 3:27pm
What weight? What do you compete against? Cubic inch limit?
So 12 MPH is your max or 17 MPH??
Edited by O.P.S. Heads - 14 Aug 2014 at 3:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 4:47pm
How do they allow a 200 with a 426 , as in its not a stock engine for a 200? Theres a guy im friends with on FB that has a kit for this but not sure about the steel flywheel part ,
Edited by DougG - 14 Aug 2014 at 4:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 6:19pm
Our div 4 is 12 our open class is 17 mph not much comp look at our web site our rules are posted delmarvatractorpullers.com there are some of us building to get this class started 6500 7500 lbs
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 6:24pm
How do they let people put a Cummins in a allis tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 9:17pm
If I am interpreting the rules correctly, division IV says nothing about turbo chargers where division V (open 17 MPH class)does. Is the division IV class naturally aspirated? Also, it mentions factory OEM cylinder head - no recast or aluminum heads but it's OK to install and engine that didn't come in the tractor???
http://www.delmarvatractorpullers.com/rules-regulations/
Good luck in whatever you decide to do. The rules are not real specific as they are posted on the web page. Before I would build anything I would get some specific answers on what can and can not be done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2014 at 10:13pm
Thanks motor is fitted in just wanted a steel flywheel fo safety
Johnkaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnkaw Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2014 at 10:02pm
Call Mark Gettinger!  (765) 977-8348  He has all the 426 peformance parts you need!
