Allis chalmers hd11
Lonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonnie Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers hd11
    Posted: 09 Aug 2014 at 9:06am
Looking at purchasing this unit current owner has a sprocket bought but hasn't found
Rollers for it. We are very interested in getting this sweet running machine usable
Again I have found this number on the back of the unit HD11E-5223. If anyone can
Help with info for finding parts or has them I'd love to hear from you
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 10:14am
I am not up on the HD-11.  i thought some models use same track and rollers i beleive same as HD-9  just more rollers and longer track.   what state are you in? your location may help find local parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 3:25pm
We are in Oklahoma. This is my first allis chalmers much less a crawler so if anyone has any parts that fit the build I'm interested but and help on rollers is nice
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 8:23pm
I think you could find rollers at General Gear- located at Boise Idaho.  www.tractorparts.com  I have bought parts there for older HD11.  I was at a parts yard in Winnipeg this spring and noticed they have a few rollers for the older HD11 as well. (Cambrian Equipment Sales)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2014 at 8:34pm
Thanks I'll start chasing those
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 5:40am
I am still have some very nice bottom and top rollers for HD11 and am located near MONTREAL CANADA if your are interest but you have to pick up to heavy for shipping
           gemdozer@hotmail.com
Gargoyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2014 at 7:57pm
I ended up rebuilding some of my rollers. The bearings were tight so I built new outer and inner flanges out of 3/8" plate. If the roller faces are worn, I have heard of refacing them with 1/4".
If you can't find rollers in good shape, rebuilding the ones you have might be in order.
as Gemdozer noted, shipping on those is going to be expensive. They are heavy..
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2014 at 11:48am
I had a custemer with  broken roller flanges and he rebuilted them but after working a copple hours with the dozer the flange was broking again and   the oil seal burned
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2014 at 9:35pm
zimmerman tractor in Versailles MO   had some HD9's  last time i was there if those rollers will work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2014 at 10:21pm
Early HD11 and HD9 do share the same rollers.  I've bought quite a few rollers here and there- usually ends up being $80-100 shipping on each.
