wire diagram on C
murphy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote murphy Quote  Post ReplyReply Direct Link To This Post Topic: wire diagram on C
    Posted: 12 Mar 2010 at 8:03am
Ok boys did the clutch valves starter generator etc. the charging system and starter have been disconnected for the last 30 years and cannibalized the wiring im not going to run a charging switch, i have the brushes spread a part how do i wire the amp meter batt. starter ? I can start it with the starter now biggest question is the amp meter. 1949 C 6 volt system reverse ground. Thanks
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 10:12am
Bump.
This page was generated in 0.062 seconds.
