WD seat arm extension
mikebrooks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikebrooks Quote  Post ReplyReply Direct Link To This Post Topic: WD seat arm extension
    Posted: 06 Aug 2014 at 10:28am
I just bought a WD, I'm approximately 6-3, and it's a little cramped. Has anyone done anything to move the seat back? It's already in the last hole. Was thinking I could maybe get a bracket welded to add 3 more holes. Are there any products already on the market or maybe a trick like swapping something from a different model? Surely I'm not the only one who finds this cramped.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2014 at 11:16am
I put about a 4 inch square oak block under my seat and used a longer bolt. Worked pretty good. I'm 6' or so and it's much better than factory. I think people were shorter in the 50's...
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikebrooks Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2014 at 12:08pm
So is up better than back?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2014 at 5:03pm
I am also 6'3" and I know what you're talking about, BUT my worry would be that moving the seat back further back would make more leverage, which would be too much stress on the existing seat support.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikebrooks Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2014 at 6:40pm
I thought about that, but I'm only talking about maybe 4-6". I worry if I go up instead, that I will be reaching my leg around the wheel to operate the brakes.
Does anyone know if the arm on a WD45 seat is any longer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2014 at 9:47pm
I think the seat frame is the same on a 45. Dad was 6'-1" I am about 6'-2" we spent many hours on them. About 90% of the time we never put our right leg on the right foot rest at the brakes. Just sat a little side ways and had both feet on the back deck. Of course if things got dice you had to get over on the brakes.
I bought a WD that some one welded on a extension with extra holes and the seat moved back. never drove it so not sure how it helped.
just make sure its safe.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2014 at 10:03pm
I have on 2 of my 45-d wher the seat arm has a series of fore and aft adjustments for the seat pan it is not an after market contraption added to the arm either.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikebrooks Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2014 at 10:31pm
Could you post a picture?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2014 at 4:06am
The seat support assembly was changed at WD serial 127007,same time as transmission gears and curved shifter.
The revised seat 'may' have more adjustment.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikebrooks Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2014 at 9:38pm
Gary
Does anyone have a pic of the differences?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2014 at 6:20pm
Mike
Look at page 201 and 202 for the 2 styles of WD seat supports.
Gary
http://www.grandpastractor.com/manuals/ac/WD-WD45/wd45-parts-book.pdf
