Left steering on an h4 crawler
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: Left steering on an h4 crawler
    Posted: 05 Aug 2014 at 6:03am
I have a h4 crawler/loader and I think my left brake is not releasing all the way. I have the left track off to replace the rear sprocket and to repair the adjusting arm so I have that side blocked up. I started the engine to turn the sprocket so I could get to the bolts better as I took them out but it acted like the brake was still engaged some. is that a hard or easy fix. any ifo is appreciated. thanks norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2014 at 12:05pm
see post on 653 AC same machine
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2014 at 6:47pm
I SENT YOU A PM TWO DAYS AGO. DID YOU NOT GET IT ? EVEN IF THE CLUTCHES ARE STUCK OR NOT IT REQUIRES A LITTLE PRESSURE ON A BAR TO MANUALLY TURN THE CLUTCH PACK IN ORDER TO REMOVE THE BACK BOLTS. I ALSO PULLED THE RIGHT STEERING LEVER BACK TO SEE IF THAT MADE IT EASIER TO MOVE THE LEFT SIDE.
This page was generated in 0.172 seconds.
