oil level in 'c'
murphy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote murphy Quote  Post ReplyReply Direct Link To This Post Topic: oil level in 'c'
    Posted: 11 Mar 2010 at 9:23pm
It manual says 4 quart but that justs touches dip stick full mark is up another inch and a half i wonder if wrong stick or is book wrong and needs more oil the full line is up about 2 inches on the stick, thanks for all your help.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 9:27pm
Make sure the dipstick is in all the way. Mine only holds 4 quarts. Hold on, i'll double-check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 9:33pm
Just measured dipsticks on both Cs in the shop. Dipstick bayonet shaft is 9 7/8" long, as measured from the business end to the bell cap(not the end of the handle. Full mark is at 8" from the bell cap. That should eliminate an incorrect dipstick, and give you a place to mark full if you do have the wrong one. Don't forget to start the engine and fill the filter before taking a final check of the level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 10:13am
Murphy, what did you find out on this?
dudley wallace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dudley wallace Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 11:33am
my c and c/a takes 5 quarts with the filter my wd and wd45 takes 6 quarts with the filter hope this helps dudley
a member of hendricks county antique tractor and machinery association club.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 1:00pm
I've always put 5 in my CA. The fiber filters will soak up quite a bit.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 8:20pm
5 quarts in my C's
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 8:51pm
Maybe it should be 5 quarts. I have mine filled to the full level, whichever it is. The measurements on the dipstick should eliminate any confusion. If the mark is at the right place, fill it up to that point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote murphy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2010 at 5:41pm
my dip stick was wrong (so i was told) thanks guys
This page was generated in 0.050 seconds.
