WC vs WF
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Topic: WC vs WF
    Posted: 11 Mar 2010 at 9:15pm
I was flippin' through some of my AC books this evening after dinner, and this thought came to my mind. Lookin' at the WC, then looking at a WF, looks like the same Tractor except the WF obviously is shorter. My question is, does the WF share quite a few parts with the WC? And how bout' the WC grille shell and hood? Are they the same or do these two models differ from one another in the sheetmetal department? Just curious. Eventually, I would like to add a styled WF to the corral....
Steve@B&B
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 9:43pm
Steve, the front sheetmetal, gas tank, grille, hood, are all the same on the styled ones anyway, the fenders are different though, they are the same as a WD fender except for the reinforcement behind them and where the brake cover is. Engine and trans is the same as WC, and later WF's, WD. HTH
49 WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49 WF Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 9:57pm
Steve, the steering is not the same as a wc and the clutch pedal and the platform for your feet is also not the same. the rear end casting is not the same as well.
66 190 GAS,49WF,B,C,37WC,48WF,3WD'S, 66ALLCROP,B1,B10,sbchevy WC
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 4:44am
The front and rear axles, steering box, and various parts in the area of the operator's station are different than a WC, most everything else are the same as or modified WC parts.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 5:54am
Steve, If your thinking along the lines of taking a styled WC and turning it into a WF I know of a pile of parts that might do the trick for ya. PM me for details.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 12:51pm
A WF is just a wheatland WC.  I got mine in Canada, up there they called it a WC.  Cute little tractor, doesnt take up much room.  HTH
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 3:19pm
Lots of WF's in my part of the world:  and they were called WF's as we also have a lot of WC's.  Local tractor wreckers has 5 WF parts tractors and my buddy near here has 3 more parts tractors.  I have a very good, two owner, original that I would consider selling to you, Steve. Shipping might be a killer, though. (Might be cheaper to fly up here and drive it back)LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 3:44pm
Norm Swinford makes it sound like they just rotated the final drives forward and designed a special ft axle to make a WF out of a WC.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 4:07pm
Sure looks like that Swinford description when I found one, though the rear axle may also be shorter than for a WC.
Gerald J.
