Weight bracket ideas
Allisboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisboy45 Quote  Post ReplyReply Direct Link To This Post Topic: Weight bracket ideas
    Posted: 03 Aug 2014 at 7:20pm
I'm planning on pulling my WD45 sometime at the local pulls we have. I recently picked up some weights and now need to fab up some weight brackets. Could somebody share some pics of there weight bracket setups? Any help or pictures would be appreciated.
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2014 at 8:51pm
If you'll pm me your number ill text you mine, but I have the hardest time posting pictures on here lol!
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2014 at 9:00pm
whatever you do, always use the same TYPE of weight, so it will hang on the front or back or wherever else you make a bracket. One of the dumbest things I see is a Puller who has 2 or 3 types on weights and cannot make a last minute change just before hooking to the sled because they have to remove one and then replace it with a different type.
This page was generated in 0.043 seconds.
