Oil Fill Tube 56 CA |
Mike(GA)
Topic: Oil Fill Tube 56 CAPosted: 11 Mar 2010 at 2:05pm |
The fill tube on the valve cover on my 56 CA is loose. How are they held on? I have not removed the valve cover to see what the problem is yet.
Larry in OK
Joined: 25 Jan 2010 Location: NE Oklahoma Points: 315 |
Posted: 11 Mar 2010 at 2:39pm |
I've recently had mine off and it appears to be pressed and/or welded. Mine is very solid.
Dakota Dave
Posted: 11 Mar 2010 at 3:18pm |
I took mine off last fall and welded it inside. it looks like it was pressed in but mine got loose enoght to leak. its been great since welding.
Mike(GA)
Posted: 11 Mar 2010 at 6:10pm |
Thank you for responding. I will have mine welded.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 11 Mar 2010 at 6:45pm |
I have had a couple loose. They are just stamped in. I pressed them in place square and spot brazed them in place in four places on the inside. If you can't get them tight I would brazed them all the way around to keep them from seeping oil.
