Slightly off topic. Gasoline pulling trucks
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Slightly off topic. Gasoline pulling trucks
    Posted: 24 Jul 2014 at 3:28pm
I know it is slightly off topic, but why doesn't anybody truck pull with gasoline powered trucks anymore. Everybody went to diesels. I get tired of watching smoke machines all the time. Haven't been to a truck pull for years since they did away with the standard street gasoline trucks. Used to be some locals that would pull with gasoline powered trucks and did very well. One even had a two wheel drive 60's chevy and it would flat pull. He'd get some daylight under the front tires and could really make it go. Wouldn't pull it real fast, but he always had a high score.
Adam
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2014 at 5:08pm
We have some really tough gas trucks around here. Still pretty competitive.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2014 at 5:39pm
Go to    bmf.com   they are from around the T-town area. They pull at alot of local pulls not far from you. I,ve seen them a couple times this year. Always put on a good show and they are all gassers.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2014 at 8:56pm
It's cause diesels are easy horse power. Put a programmer on them and look out. My 02 duramax is stock 300 hp. In less than 2 minutes I can make it 525. Who wants to build a motor to make horses ? The gas trucks around here run in same class. Run whatcha brung. And they are competitive with the diesels.   Shawn
190XT,D17and 7045
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2014 at 10:13pm
We still have a pretty good gas truck showing, but I honestly don't spend much time around truck pullers. Tractor pullers are a lot friendlier and nicer to talk with. Maybe it's just my area.
