8050 Allis |
Cummins
Topic: 8050 AllisPosted: 10 Mar 2010 at 5:15pm |
Do you guys know how to turn an injection pump up on an 8050 Allis? thanks |
DrAllis
Posted: 11 Mar 2010 at 7:07am |
Really shouldn't be done without a dyno to verify the beginning and ending results. Remove the four bolts holding on the pump governor cover with a 7/16" socket. Locate the horizontal adjusting screw under the cover. Loosen the jam nut (7/16" open end wrench) and turn the screw with a flat blade svrewdriver "out" (counter-clockwise)) 1/2 turn and reset the jam nut. Re-install the cover.
