power divider
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Topic: power divider
    Posted: 19 Jul 2014 at 9:21pm
Is it a big job rebuilding the power divider in an allis 200. Is there anything heavier duty to use. Would really like to keep it in use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2014 at 9:52pm
What are you trying to do?????? Farm or Tractor Pull??
pohlman249 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pohlman249 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2014 at 12:50am
The guy who rebuilds some parts for Mark Heitman worked in extera disks on his pulling 200 and built a steel band around it incase of failure. Shift up is ok but down when pulling with it in his application is a big no no..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2014 at 8:26am
Pulling with it. I turned pressure up to 320. Wheels stop in my heavier class I don't think it's main clutch but I have new clutch to put in just figured it is apart I will check power director. 8500# &9500# class. It is the stock clutch now
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2014 at 9:24am
My money says your old foot clutch slipped. A healthy PD clutch with 320 psi of pressure and properly adjusted/not worn linkage will generally hold more HP than an old foot clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2014 at 10:34am
Linkage is in good shape tractor only has 1600 original hours. I have a new button clutch and heavy duty pressure plate. Thought while it was apart I will check in to the power director. Tractor runs strong after rebuild and hx35 turbo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2014 at 11:38am
Prolly a broken clutch disc in the PD, had one do the same thing, also double check the linkage, 200,s are bad for that- bushings, platform movement etc
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2014 at 3:01pm
Your foot clutch must be slipping. A good P D will hold lots of power once locked up . I can pull 10,500 lbs in 6th gear at 3,500 rpm and don't slip a bit and will spin her out at that weight, at 13 mph.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2014 at 7:47pm
Never had one apart was wondering I have to put new foot clutch in if I should check power director. I thought when it slipped think u would smell clutch that's why I was thinking It was power director.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2014 at 7:58pm
No smell. Tie a tile flag onto the PTO shaft and position it so you can actually see the PTO shaft when it turns. Set the brakes hard. Place tractor in 8th gear and with the PTO ENGAGED and engine full throttle, release the foot clutch. Hand clutch slipping?......PTO is running. Foot clutch slips?.....PTO doesn't turn. Any questions??????
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2014 at 5:23am
Thanks DrAllis I'll try that
This page was generated in 0.176 seconds.
