equalizer hitch?
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Topic: equalizer hitch?
    Posted: 09 Mar 2010 at 7:16pm
Anybody run a equalizer hitch on their trailer.  I pull an 18' tandem axle  with my 3/4 ton pickup.  Sometimes it wants to pitch a bit when i hit bumps or uneven pavement.   I don't haul very heavy loads.  The B about 2500 lb and WC about 3500, pickup is usually empty so would be nice to move some load to it.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:21pm
  load so you have tongue weight  will help a lot
RickUP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickUP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:23pm
Equalizer hitch is used when you have too much tongue weight and cannot change it. For your problem, I change location of tractor forward or backward till I get a good ride with the proper tongue weight. Hope this helps. G. luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:28pm
Makes sense, sometimes it seems better, maybe just by luck I load more to the front on occasion.   Sorry I got this on wrong forum, sure don't need more traffic here.
Edited by Rick of HopeIN - 09 Mar 2010 at 7:30pm
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:49pm
I have an Equalizer that I use with my Camper. It makes a huge differance in the way a trailer pulls. You can't use it off the road. they transfer some of the wieght to the front axle of the truck. When you drive across the road expansion joints instead of bucking the trailer and truck act toghther
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 8:23pm
I use an equalizer/stabilizer when tagging a heavy trailer behind a pickup. The safest load is a trailer loaded heavy forward with equalizer transferring what would be tongue load to the front truck axle, along with the stabilizer system keeping truck and trailer unified in a straight line. The equalizer also provides much better truck braking power by transferring sufficient weight to the front truck axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 9:32pm
I also have one that came with my travel trailer.  It works awesome on transferring tongue weight to the front of the truck and keeps it from swaying on the highway in windy areas.  I love it.
