185's 649 starter on a 433?
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: 185's 649 starter on a 433?
    Posted: 09 Mar 2010 at 9:07am
I have a 433I that I wanted to upgrade starter on to help it turn over faster for easier starts.  When I asked my AGCO parts man about using a Iskra type (japanese) starter for this, he said that I should try taking a AC 185's 649 starter and swapping into the 433I engine.  Apparently, he said that the 185's were equipped with a 2x faster starter motor.  Anyone done this?
oregontrailbeans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oregontrailbeans Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 10:17am
I used to  have  a 6080 and a 185 I thought the 185 starter might be a little to long. would be a good idea. I can remember the 6080 always cranked slow compared to the 185-190-190XTs
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 4:52pm
Id stay far away from an Iskra, we used to use em in the construction line and had boo coo problems with em.  A 185 should have the Lucas  starter which is shorter than the ole stanby Delco starter.  The Lucases had weak fields and wouldnt take near as much as a Delco.  I dont think the Delco will fit the 433, Im thinking they came with the Lucas.  I dont know about the speeds, I was under the impression they were the same.  Sounds like yours might be getting weak.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 5:24pm
I called my starter supplier & he explained that the 433 starter is a class 25MT while the 185's 649 starter is a 35MT class.  Apparently, the 35MT is much bigger in size, so it is not an option.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 5:58pm
Check the bearings in your starter. New ones are not hard to put in and often make quite a difference. If the old ones can't be driven threw run a tap in the old one. Screw a bolt in and pull the bolt and bearing out.
Dusty
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:14pm
The late-model 8010 tractors used a gear-reduction starter that is much smaller in physical size.  Might be an option?
Nippondenso - a.k.a. "Denso" starter, A-C part number 70273901
Dave King View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave King Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:46pm
It matters a lot who built or rebuilt your starter.  The guy I used to work for has about 13 855 Cummins irrigation engines, so we'd go through 40MT starters quite often.  The local NAPA carries Wilson rebuilds, and the Federated Parts place carried Anderson rebuilds.  The Anderson starters could be cranked with just the 00 jumper cables, but the Wilson would use a 1000cca battery plus the jumpers, and would never crank over as fast as the Anderson.  Good cables with marine posts will help too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 10:16pm
Get a nippondenso gear reduction starter and you will never be sorry. Run from a lucis, they were junk when they were new.    MACK
