P series pump options on a 426
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: P series pump options on a 426
    Posted: 05 Jul 2014 at 8:24am
Im kinda new to P pumps and planning putting a prostock together with a 426 engine, but gonna resleeve it for 466 with hardened rods: class is 9500 lbs, 3000 rpms,3
.o inlet on turbo and water is allowed, my question is what a good pump to look for? I can change the front plate and all that just not real familar with big pumps
Edited by DougG - 06 Jul 2014 at 10:46am
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 1:57pm
the front plate just needs machined out to accept the lager pump im guessing, im a 301 guy and depends on how much fuel and class rules here its a-pumps and P-pumps depends on set up and weight inter cooler or not in a limited pro
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 5:26pm
Get everything else done first and buy your fuel system and turbo last. Technology on these pieces changes all the time and they are the most important power making items.
My buddy uses a Bosch P3000 from a John Deere tractor (40 series?) They have a nice governor for pulling. All the innards will need to be replaced with good stuff - cam P's and B's etc. I would not use anything but 13mm plungers. Sometimes you can find a nice used pump on the Pull Off, but that's always a buyers beware deal.
Edited by O.P.S. Heads - 07 Jul 2014 at 5:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2014 at 7:24pm
Easier to hang a "P" pump on a 7000 series or newer block versus a D21- 210-220 block.
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2014 at 5:22pm
Mounting a P-pump on a 426 will require you to cut one mounting "ear" off the pump so it will fit.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2014 at 5:25pm
Here's one im working on. Cut the ear off and had the drive hub made from a hub off the newer roosamaster.
This is a core pump also.
Edited by peterson - 08 Jul 2014 at 5:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2014 at 6:26pm
Thanks for the info
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2014 at 9:36pm
I have heard you can reduce the O.D. of the pumps front bearing support to fit the stock hole in an Allis plate. This could be an option if you don't have a way to bore the plate and keep it on center. You have to clearance the front plate and timing cover for the rack cap on the front of the pump also. Be sure to build a brace at the rear of the pump which ties the pump to the engine pan rail bolts or something solid toward the rear of the pump to keep it from moving. All of this work should be done before the pump is built(obviously).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2014 at 2:20am
Right on, i heard they need support as being very heavy hanging back there, this is all pre planning stuff, thanks!
