TL-12 experts question
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: TL-12 experts question
    Posted: 03 Jul 2014 at 6:18am
for you TL-12 owners.  Do the Pre 1960 redesign models with diesel engine have the same frame as the gas models?  My gasser that i thought was a steal has a lot of blowby and im pretty sure it needs and overhaul.  I am entertaining the idea of transplanting a diesel into it (252) as I plan to use it and would be better on fuel.  (yeah, expensive and a lot of work)
 Looks as if the rear axle pivot would be in the oil pan, and a really tight squeeze to get it in there.
otherwise loader is in very good condition,   i will not be chopping anything up to change motors,  if im dreaming and its not a direct swap, i will just overhaul the 17 gas engine and put it back in.
iceberg210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iceberg210 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2014 at 8:40am
My early TL12 had it's engine replaced with a 353 Detroit which sort of fits, although they had to move some parts around to make it work. I would think the diesel would bolt right in cause I'm pretty sure there wasn't really any difference between the two besides for the engine, but I'd want to do a bunch of measuring first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2014 at 7:19pm
i didnt think there was much difference either.  since my first post i measured a 230 gas engine i have and also put the tape to the TL-12.  the engine would fit with the radiator moved back a ways, but i cant understand how they get it past the rear axle pivot.  on a TL-10 2wd, it would be easy, with only a steer axle back there.  but the TL-12 drive axle pivot sticks up into the engine compartment and really doesnt clear the 226 gas crank pulley by much.   i would really ike to see some pictures of a diesel to see how it was done.
This page was generated in 0.107 seconds.
