D-17 Brakes
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Brakes
    Posted: 08 Mar 2010 at 7:54pm
What are some methods some of you have done to remove pin on the brakes?
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 5:07pm
Lots of heat with the blue wrench in the axle housing where the pin extends to the outside.  the ones that arent to tight you can get a puller on the end.  The real, real bad ones come out in short chunks, cut em with the blue wrench.
AndyinWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyinWI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 6:08pm
i have drilled and tapped the pin to 5/8 then used a short piece of pipe that was a little bigger diameter than the pin, 5/8 bolt, and a big washer, then stuck the bolt through the pipe and screwed the bolt into the pin, came right out with an impact wrench.
Hope this helps,
Andy
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:30pm
 lots of blaster aN SOME HEAT ON REAR HSG.  1-574-342-4545
  WE HAVE A PULLER  DO NOT HURRY IT
This page was generated in 0.053 seconds.
