WTB 7080 parts
SCPAAndy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SCPAAndy Quote  Post ReplyReply Direct Link To This Post Topic: WTB 7080 parts
    Posted: 08 Mar 2010 at 6:27pm
I am searching for the following for my 7080:
-rear 38" rim centers and wedge locks
-electric mirrors and switch
Its not much of a list but what i'm in the market for right now.  The electric mirrors and switch won't be a big deal but the rim parts are exclusive to 7080's according to Agco parts online.  I didn't take the time to check other manufacturers yet just seeing what others may have first.  Thanks- Andy
tnac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnac Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 6:46pm
I know where there is a good used 7080 near me someone can buy worth the money. New tires and duals.  I'd say around 7500 or 8, I can find out if anyone is interested
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 10:12pm
Yes: the wheel castings are exclusive to the 7080, but i do believe that most any two piece wedge, 38" Allis Chalmers wheel casting will work if you have the axle wedges for the 4.00" axle. The 7080 38" wheel castings are thicker and heavier (approx 600#) than any other 38"  Allis Chalmers wheel casting I've delt with. The wheel rim clamps (both power adjust or double bevel) are the same.
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:04am
i would have some cast centers off of a 7580 i think they are the same axle size, i will check and see. call me if interested, 507 421 0213.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:26am
7580 axle size is 3.75 not 4.00,but the axle wedges should be interchangeable with any two piece wheel casting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:31am
Opps; that should read   > any two piece wedge, wheel casting.<
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 4:52pm
If you get that far, I have a set of wedges off of a 7080 that I would sell cheap.  I bought the complete wheel setup to put axle mount duals on a 7045, then bought wedges to fit mine.  417-850-4532
