F.S. Like new HD Dozer blade
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Topic: F.S. Like new HD Dozer blade
    Posted: 27 Jun 2014 at 11:34pm
I have a nice 46" Spring trip snow/dozer blade for sale. It fits AC 700 and 900 Series. Simplicity 3300, 3400, 7000, 7100, and 1971 and newer Sovereign series. The previous owner said it was new but there is some minor paint loss on the edge of the shoes and the wear edge. I believe it was probably at least attached to the tractor once. There is also a slight kink in the upper RH corner of the blade but its minor. Overall its difficult to find a blade in this good of condition. It just needs the dust and cobwebs cleaned off SmileThis blade angles from the seat and all linkages and brackets are present.
Price is $250.  I have this stored in the shed until it is picked up.
Edited by ACmowerguy - 27 Jun 2014 at 11:46pm
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2014 at 8:03pm
Would this fit the Allis Chalmers 410 tractor
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2014 at 11:36pm
Fred, I used to have a 416 with a B-Series blade mounted on it. The lift rod had been lengthened as well as the lift point on the hitch (push bar) had been slightly modified. It did seem to work. It was like that when I bought it. This blade is for an AC 700 or 900 Series but I think will also fit 400's. The 300's had a different front axle and this blade will not fit the 300 tractors. It looks just like the white colored blade you posted pics of except the rear hitch uprights look larger on yours.
This page was generated in 0.178 seconds.
