D17 oil leaks
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Topic: D17 oil leaks
    Posted: 08 Mar 2010 at 2:19pm
My ser 2 17 is leaking out of the holes under the brakes.  This tractor set for years and now with little use the last 4 years it has started to leak.  I overhauled the motor along with clutch, seals, brakes and bearings in the final drive.  i guess after sitting and being old it decided to leak after some use.  i have an IT manuel and would like to know how big a job this is. I'll eventually tackle it when i have the time.  Just don't like oil leaks.  THX, Jim
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 2:51pm
Probably the seals in the diff bearing carriers are leaking.  Youll have to take the brake out and pull the axle.  The axle shaft goes thru the carrier seals.  Only take one side out at a time so the differential doesnt fall out of place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 6:01am
Thanks Skip.  Jim
