Allis G Head
Morris Hill NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morris Hill NC Quote  Post ReplyReply Direct Link To This Post Topic: Allis G Head
    Posted: 08 Mar 2010 at 12:02pm
I just finished building a Allis G engine ,Got it timed and running sounds good
 about 25 lbs oil pressure gen charging on high and low.
Problem  Water seeping out of center head bolt between #2 & #3 sparkplug
I used lock washers on studs and it seems to be leaking at split in washer.
Should I have used a flat washer Or do I have a HEAD problem?
{I know I have A head problem, I am talking about the Tractor}
Thanks
Morris
ac_bowsers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_bowsers Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 12:49pm
Is that the bolt on the water neck? I just got done with one here and mine started seeping out on the front bolt of the water neck, I was told that was the weak spot on those heads in front of the neck, mine has been repaired there and pressure checked good. I pulled the bolt up and put a dab of form-a-gasket 2 on it and snugged it back up, no leaks now. Try that first, you may have a cylinder head problem. Just my two cents...good luck
Pine Stock Farm "Home of the ALLIS" 35-WC-36-U-37-UC-47-C-49-G-57-D17-58-D17puller-63-D21-71-210puller-79-7045-83-8070-AA9675-BigTen-B10-310-1300fieldcult-snapcoupler imp.-longhopper blower,signs,etc.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 12:51pm
copper washers. That was what was  on mine when I disassembled it. I picked up a copper washer assortment a Harbor Freight when they were on sale. I don't remember the cost but seemed like it was only a little bit more than if I had bought a hand full one at time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morris Hill NC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 7:23pm
AC Bowser & Dick L
Thanks for the info on G head ,will try washer & sealer.
Thanks againMorris
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2010 at 8:29pm
Harbor Freight copper washer storehouse $9.99
Handy to have on hand.
