Fairbanks Morse Tool
WC Fields(N_ILL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Fields(N_ILL) Quote  Post ReplyReply Direct Link To This Post Topic: Fairbanks Morse Tool
    Posted: 08 Mar 2010 at 7:19am
I came across this in the basement of a deceased relatives house. It appears to be some sort of vacuum or pressure vessel. The lid has a gasket similar to a Ball jar. It's about 3 gallon capacity. It has 2 hose type fittings. The cover is clamped by the handle swinging to the vertical position. It is cast aluminum and pretty thick. It almost resembles one of those suction bleeder tools. There is no tube extending down inside from either fitting. There is maybe a valve on one fitting that a small handle may have snapped off. I've never seen anything like it and wonder if anyone has an idea. This may have been procured by my grandfather in the 30's or 40's as he worked at Fairbanks from the time he was assembling windmills till his retirement.
37 WC   49 WF   53 WD   67 D15
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC Fields(N_ILL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 10:30am
A friend tells me it's part of an old milking machine system. Fairbanks also made the scales to weigh the milk.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2010 at 11:12am
I was just going to say it looks like an early milker.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 7:25am
Yep, If you had a few more parts you could hook it up to you Allis tractors manifold and milk the cows instead of doing it by hand.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2010 at 1:00am
In Steve Wilkins book, Nanas Willow, one of the neighbors uses a vacuum powered milker on his WC.
Allis Express participant
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 10:41am
bump
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2010 at 4:59pm
Your missing the pulsator, claw, teat cups and shells and hoses for the bucket milker. Then you need a vacuum pump and a cow to use it on.
This page was generated in 0.227 seconds.
