Briggs Model Number for Big Ten
RickSoKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickSoKs Quote  Post ReplyReply Direct Link To This Post Topic: Briggs Model Number for Big Ten
    Posted: 15 Jun 2014 at 9:56pm
Working on my grandsons Big Ten garden tractor.  Trying to find crankshaft, connecting rod, rings and gaskets for the briggs and stratton ten horse engine. Need the model number, type and code to look up parts on the briggs and stratton web site.   Thanks
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2014 at 10:58pm
The code is unique to each engine, almost like  a serial number. Most of the cast-iron engines will not look up properly on the B&S site. You can email them and they will send you the parts manual.
Model # for the engine is 243431
Type # is 0123-01
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickSoKs Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2014 at 5:19pm
Ok, I will send them an email.     Thanks,    Rick
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2014 at 6:38pm
The bad news is, almost none of that is available any more.  The code info should all be stamped into your shroud.  I have the parts manual in a pdf if you have no luck with briggs.
AaronSEIA
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2014 at 7:14pm
I have a complete engine I believe is good, can ship.
Edited by Chris/CT - 17 Jun 2014 at 7:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickSoKs Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2014 at 8:44am
Just wanted to say thanks for all the help.        Rick
This page was generated in 0.104 seconds.
