712H starting problems
mustang99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mustang99 Quote  Post ReplyReply Direct Link To This Post Topic: 712H starting problems
    Posted: 10 Jun 2014 at 3:06pm
hello everyone! I am new to the forums and I recently was given a allis-chalmers 712 Hydro riding lawn mower. I was told that it use to be one of the best riders you could get. I just thought my aunt was kidding until i did more research and saw all the things this model could do like snow plow, mow, etc.
So a couple of questions, how do i know if i have a 3 speed gearbox and more importantly how do i get my rider started? I know the battery was dead so i charged it and now when i turn the key i hear a click but nothing happens. No turning of the starter or even a noise of the starter wanting to turn. i have a test light and saw the power was going to the spark plug at least but i'm not sure how to test a starter or the starter solenoid.
Is there a way to bypass the need for an electric starter? I think riding lawn mowers would be MUCH better if they had pull starts. Thanks for the help guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2014 at 10:00am
First - if it's a 712H the "H" means hydro transmission and you simply adjust forward/rear speed by adjusting the right hand lever either forward/rear.    There isn't a separate 3 speed gearbox.   Allis also made a non-hydro 6 speed version of the 712.
2nd regarding the starter.....  If you hear the selenoid click it sound like it is working.   When you turn the key (might need 2 people to do this)...check if you have voltage on the output terminal of the solenoid going to the starter.  If you do then you need to check the starter.  It removes very easily with 2 bolts from the engine (after the cable is unhooked).   Take it off and see if it turns freely.  You can then use a set of jumper cables to hook it to a battery (+ to the terminal post and - to the frame to ground) to see if it runs.   If it runs hooked to a battery you may want to put a set of vice grips on the front engine shaft to see if you can turn it over by hand..could be somewhat stuck if has been sitting around for years and not started...
I just pulled my starter off my 712H last weekend and it turned out to be toast inside as the permanent magnets were busted (that's why you don't tap on the outside per the warning sticker).   New starters for a Kohler K301 engine look to be about 50 bucks or so from my quick check on ebay but I need to be sure the new ones work on an older versions like my 712H.   HTH.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2014 at 11:21am
When things are clicking, that means power is going to them, the component or the connection is faulty. The first thing I would do especially if its been sitting for ages, is to clean all the connections up. Mother Nature gets into all those connections, makes corrosion, and a low voltage situation happens. Hence the "click". Remove the cables from the Battery, clean the ends going to the starter solenoid, and the starter motor and re-assemble and give it a try. As Mike mentioned, make sure the engine turn over and is free also. If the engine is stuck, that would give you the same scenario with the "Click".
Any of the 700 series AC Tractors are tough machines, and can do pretty much any type of work from tilling, to plowing and the basic mowing...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote mustang99 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2014 at 3:57pm
I was able to turn the crank from the front by hand. Didn't even need a vice grip or anything. The mower last ran a month or two ago and then stopped running due to a battery is what she said. Connections look decent just lots of dirt from all the times it mowed. Although due to its age i might just replace the switch, solenoid and starter and call it good. This electrical testing/troubleshooting is making my head spin.
