D19 Question |
Ken(Bell.Wa)
Joined: 12 Sep 2009 Location: Bellingham, WA Points: 164 |
Topic: D19 QuestionPosted: 07 Mar 2010 at 12:13am |
Changing trans and diferntal oil on our just purchased D19, I believe the diff and trans have seperate oil resivors and need to be filed and checked seperatly, Is this correct, 80-90wt in both I assume. Thanks Ken
Kevin(Alabama)
Joined: 12 Sep 2009 Location: N.W. Ala. Points: 578 |
Posted: 07 Mar 2010 at 12:47am |
You are correct. Check trans with dip stick, and dif. with the check plugs.
"I would die a thousand deaths before I would betray a friend."...Sam Davis, Nov. 27, 1863.....DEO VINDICE
DrAllis
Posted: 07 Mar 2010 at 6:31am |
Transmission AND differential are together (and have two drain plugs)...each final drive is on it's own......a left final drain plug and fill/check plug and a right final drain plug and fill/check plug. Each final drive holds approx two gallons of 80/90 wt. The trans/diff holds approx 8 gallons of 80/90 wt OR modern day universal hyd fluid.
Kevin(Alabama)
Posted: 07 Mar 2010 at 9:08am |
De Allis has corrected me. I should have said finals instead of differential.
