WD45 trans. parts needed
Chris WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Topic: WD45 trans. parts needed
    Posted: 06 Mar 2010 at 7:15pm
I need a good third gear and shift collar for a wd45 fourth is not much better so I could probably use fourth too.  The guy I am fixing the tractor for does not want to spend too much to get it working but he rakes hay with it and it pops out of third.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 7:47pm
I have 2 45 [ 1 gas,1 diesel ] skeleton's out here I could look inside of to see how they look, could sell you complete gear set/shaft. WQould need some time to tear into them to get parts out. Keep me posted if nothing else if offered more quickly.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 8:03pm
I have a parts wd45 outside Reedsburg Wi
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 9:46pm
acd17toy your inbox is full can't get a message to you . Ask Phil for my Phone Number
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 9:55pm
This brings up a good question. Is new aftermarket parts available for this transmission or is the only hope for used parts? I have one to go through some day.  Dave.
