200 turbo
WALLACE220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WALLACE220 Quote  Post ReplyReply Direct Link To This Post Topic: 200 turbo
    Posted: 04 Jun 2014 at 10:49am
I'm needing to replace the turbo on my 200, it's a stock tractor and was curious what a good brand would be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 12:39pm
Unless you are a fabricator, you need to stay with the same brand/model for oil lines and plumbing to fit.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2014 at 10:57pm
The TO4B80 is fine - if you want a little upgrade go with the same turbo but with a .58 instead of a .69 A/R exhaust housing on the stock tractor. It will up the boost 2#'s  - it was std on some industrial applications and 7020's and combines.
ACfarmboy24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACfarmboy24 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 7:47pm
So will an AIResearch TO4B80 bolt right on my 200? Or will I need to get it fabricated to fit like DrAllis said? The 200 needs a turbo pretty quick.
AC 200, AC 7045, NH 4630, White 508, CIH 5600, Athens 76, AC 333, Hesston 545
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 8:38pm
Bolts right on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACfarmboy24 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 8:40pm
Thanks DrAllis!
