D-10 identification.
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Topic: D-10 identification.
    Posted: 06 Mar 2010 at 12:33pm
Is this a standard dash? I looked through my books and I saw nothing like this. Let me know. This must have been a county tractor because it is yellow underneath it, and it is not the primer. This is a series 2.
"Better By Design"
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 3:49pm
Many had a hole for the traction booster if installed. Mine has a fuse in the center with a dash light, light switch and key above the 4 larger holes. No lights on this one ? The dash should fit down snug with the part that has the gear pattern stamped in it. Looks like yours should go down and/or forward some - a bolt on each bottom corner of the dash that fits into the torque tube and also threw the side shields not present in your picture. Looks factory other than gage on top right to me.
I used to be young and stupid, now I am not young anymore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 4:11pm
This has no hole for the lights...tho is should have lights on the front. no fuse holder hole. I think it fits how it should. I don't know what to say about this..I haven't seen one like this.
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 10:58pm
Are there lights or at least wire running to lights for this tractor ? Maybe they had industrial units without lights. If it has lights - how would you turn them on ? May not be a common dash - but I think it came from factory like that or replaced from another tractor. Can you show another picture of how the dash is fixed to the torque tube ?
pineyjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 4:26am
look's like my I 40,go on yellow forum for plc's
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 8:20am
well..there are no lights on the tractor...but the shroud has the type that holds the lights in the front. but that must have been put on after the fact...along with the fenders. So..maybe this was non lighted industrial model.
"Better By Design"
