D 10 S II & S III difference
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Topic: D 10 S II & S III difference
    Posted: 05 Mar 2010 at 3:04pm
The D 10 S I & II have a rectangle piece that has the gear shift pattern stamped in it and fits under the dash and bolts to the torque tube. Am I right that the S III does not have that part ?? The S III dash is more rounded on the bottom and fits to the torque tube, Did they have a decal with the shift pattern ? Reason I ask is I am putting a S III back together after 2 years and I can't find the shift pattern part. Did I misplace it or did they change it while I wasn't looking ? Thanks, Larry Miller
I used to be young and stupid, now I am not young anymore.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 3:51pm
My D-10 series III has a decal shift pattern that's no longer legible. For now I have a piece of duct tape stuck to the transmission with the shift pattern. A little crude but id works.
Dusty
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 8:55pm
Dusty, where is the decal for the gear patern located?  On the gas tank?  Or is it on the transmission housing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 6:03am
My D-10 is home in Michigan and I'm in Florida yet so it's a little hard to go out and check, but if I remember right the decal is on the gas tank.
Also there are two different decals. One for the D-10 with the 2 speed gear box in front of the transmission. And one for the standard D-10.
Dusty
Dusty
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 6:55am
Shift pattern is a decal located on the gas tank just above the fuel gauge. There are 2 different ones, standard trans or one with range trans. I have the decals for the range trans. Let me know what you have.
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
