Hard starting D-15 |
MaxinSC
Joined: 05 Mar 2010 Location: Anderson, SC Points: 14 |
Topic: Hard starting D-15Posted: 05 Mar 2010 at 10:54am |
I have A D-15 that is extremely hard starting. The gas lever must be all the way to the top( no throttle). If the battery gets low voltage (enough to turn the starter, but not Full speed), it will usually not start. Sometimes it will fire up just as you release the starter push button. Would one of the electronic ignition units help this problem? If so, where do you get them and are they very complicated to install? Also, does it require a new coil to go with it? Thanks for any help.
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 05 Mar 2010 at 11:34am |
Max - Lot of questions. Itsounds like like you have a weak battery. Take it to a auto store and have it checked out. You may have a starter that is drawing excess current.
Your excess current draw can cause low voltage to your coil, thus low spark. The electronic IGN also need adequate to operate, will not usually operate below 10.5 volts.
The Electronic IGN is not hard to install. Someome on here will probably be able to give more info on a unit. - AL
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 05 Mar 2010 at 7:03pm |
I agree with Al. My Oliver 60 used to do that. Never would start cranking, but as soon as you let off the button, it would light off every time. Turned out the battery had a bad cell. Cranking voltage was dropping below 9V. It still cranked good because the starter was 6V. A new battery and it starts right up.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 05 Mar 2010 at 7:58pm |
The throttle having to be closed sounds troublesome to me. Maybe carburetor problems, maybe vacuum leaks in the manifold?????
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12018 |
I agree with the guys. Sounds like you may have a problem with the Battery. Also, an E.I. will help with faster starts. Get your Battery checked out first. You can always add an E.I. anytime. I sell the E.I.'s for the AC machines. If you would like to order one down the road, drop me a line. Be glad to help you out. Nice detailed instructions come with ALL E.I.'s.
Steve@B&B |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24768 |
Posted: 05 Mar 2010 at 7:59pm |
Al's hit the nail on the head. I'd toss in a known good battery,replace the cables with new ones as well. A wee bit of corrosion down the center of a cable will drive you nuts! My 'new' '59 D-14 has everything new(plugs,wires,coil,points,battery cables and battery). You can't get your hand off the key fast enough! 1/2 a spin and she's purring. No need to 'upgrade' to electronic ignition,heck the Kettering system was good 60 years ago,and it's still good today.
Jeff Z. NY
Posted: 06 Mar 2010 at 4:29am |
I'm with Jay on this one. First have the battery charged and then load tested.
I can't count the number of service calls I have done on tractors that wouldn't start when the owner said dead battery. 90% of the time it turned out to be loose and dirty connections. Clean all connections and don't forget to do were the wires connect to the battery terminal if you have the clamp type. Remove wires from starter and soleniod and clean those connections also.
