Backhoe Teeth
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Topic: Backhoe Teeth
    Posted: 23 May 2014 at 5:16am
I need a tooth for my 4500 Ford backhoe. Who carries those and what do I look for? Thanks.
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2014 at 5:56am
Check out ebay alot of choices????
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2014 at 6:35am
Scott  I needed some teeth for my IH backhoe and went to my local John Deere industrial dealer (they sell yelow stuff) and they had a big book with pics and after we found one that looked the same he checked part number and went to wear house and came back with the teeth I wanted.   I have the impression they can get teeth for any model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2014 at 8:13am
Teeth are consumables and like many things that wear fast - many mfg out there . Any industrial dealer can supply several brands and types . Size vary also so measure the part welded to bucket and the placement and size of hole in the mount.
 Some teeth are pin on others clamp on . Pins differ also in type with roll pin type to rubber center drive in .
 Also tooth design for different materials , frost , rock , and others for special use.
So a New Holland , JD, Case, Industrial should have what you need as well as other construction supply houses should stock or be able to order them.
