CA Rear Oil?
acisbest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Topic: CA Rear Oil?
    Posted: 05 Mar 2010 at 7:56am
Hello,
What type of oil should I put in the rear of my CA?
I have a C that calls for 20 wt oil.
The CA hydraulic pump is a little bit different, so I'm not sure what to use.
I guess I could try to find my manual but I'm at work and would like to stop by a store and grab some oil on the way home.
Thanks.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 8:16am
Lubrication called for in the CA is the same as in the C. S.A.E 20 W for above 45 degrees F and 10 below. Most everyone agrees todays Hydraulic/Trans oil is just fine since the hydraulics and the transmission both share the same lubricant.
This page was generated in 0.057 seconds.
