Question about B model
RobbyH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobbyH Quote  Post ReplyReply Direct Link To This Post Topic: Question about B model
    Posted: 04 Mar 2010 at 10:51pm
I am seriously looking at a 40's B model that looks real good.  The issue I have is that while it idle good, as you rev up the RPM's it wants to sputter as if a coil is going bad, points bad (has been converted to a distributer from the magneto) or a carb issue.
The question I have is (1) would either of these three cause a sputtering issue; (2) any thing else that might cause it and (3) since it hasbeen converted to a distributer, how hard is it to find points, etc for it or to convert back to a magneto?
Thanks
Robby
FRANKO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FRANKO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 11:44pm
Yes, what you have identified could cause sputtering or missing.  I would check out in order of most likely reason first,
1.  Lack of fuel.  Could be a restriction from the tank into the carb, a dirty carb, or carb  load jet adjusted too lean.
2. Weak spark.  Could be caused by corroded points, weak condenser, or weak coil, or a low voltage to the coil.  If your tractor has the later model Delco distributor, parts are readily available at an auto parts store or from vendors on this site.
3.  Bad spark plugs.
4.  Leaking intake valves caused by burned valves or misadjusted valve clearance.  Check compression pressure in each cylinder with the spark plugs out.  They should all be within 10PSI of each other.
It is a good idea to check timing.  That could cause a lack of power but generally will not cause sputtering.  If you do all of the above you will have done a good tune-up and assuming the valves check out OK, it should run well.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 6:17am
Did they put a distributor on it or try to make a distributor out of the mag? I bought a b once that they used the mag for a dist but it wouldn't advance the timing and wouldn't rev. I put a different mag on it and it runs great.
ACJohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACJohn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2010 at 8:50am
The fact that is runs is key.  Unless the price is an issue, if you can fix it yourself, the "fix" to the issue shouldn't cost too much unless you are buying a mag.  Then you're looking at about $300 outright for a rebuilt "hot" one that will light 'er up with a 1/4 crank!!
This page was generated in 0.049 seconds.
