Clutch
shaunAC220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shaunAC220 Quote  Post ReplyReply Direct Link To This Post Topic: Clutch
    Posted: 16 May 2014 at 5:36pm
Im looking for 220 clutch that will hold about 400 hp. i don't know if i should go with a 8,6 or 4 pad and do i need a beefed up pressure plate?
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2014 at 2:18pm
The fewer pads the better. A four pad with a really stiff pressure plate should do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shaunAC220 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2014 at 9:26am
I've been looking for a 4 pad and I can't find one. Any ideas where I could get a hold of one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2014 at 10:00am
High-Capacity Mfg can make you one or get one for a 210 instead of a 220. You still need a pressure plate with stiffer springs to go with the 4-pad clutch disc.
