611 only moves if clutch is partway engaged
danoman86 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote danoman86 Quote  Post ReplyReply Direct Link To This Post Topic: 611 only moves if clutch is partway engaged
    Posted: 12 May 2014 at 11:47am
I have a 611 of my Dad's and its been sitting in the shed for the past 3 years and worked fine as far as i know when put away, got it out the other day and got it running, but wont move forward or reverse unless i engage the clutch halfway, then stopped moving completely even with the clutch partway engaged. Any thoughts on what could be causing it?
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 12:30pm
Check to see that the shaft going into transmission is turning! And you can do this with engine off! Put in gear and turn pulley by hand. If shaft is turning and axles aren't, then it has problem in transmission. Might also check the keys in the rear axle - wheel hubs-rim? But doubt that the're out! As most time hubs-rim are froze tight on axles and you can't remove them!
Edited by farmtoybuilder - 12 May 2014 at 12:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 12:47pm
Check belt tension as well as the path of belt - Is the idler pulley spring attached or stretched ?
 If it worked 3 years back - should now unless belt is shot .
This page was generated in 0.193 seconds.
