New toy - some assembly required!
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: New toy - some assembly required!
    Posted: 03 Mar 2010 at 10:39pm
I recently purchased a 1965 Allis Chalmers 190.  It has wide front, is a diesel, and has the snap coupler hitch instead of the three point.   I was lucky enough to get the original grill as well, although its going to take a little work to get it back in shape (it fell off while the tractor was working).  Its in good shape, but after trying to get it started the engine just siezed up.  It was turning over fine, and then just locked up.  I could turn it about a 1/8 turn either direction by hand though.  Turns out that mice had packed the exhaust manifold full of acorns and when we tried to start it they were sucked/fell into the cylinders and locked it up.  Luckily no damage resulted.  So now I am in the process of rebuilding the top end.  Let me know what you think.
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 11:01pm
A little rough but snap coupler 190's are hard to come by.Now all you need is a snap coupler 5 bottom plow to hook up to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 11:07pm
Really its not as bad as it looks.  Dust just makes it look really faded.  Also the front tires are not correct, but I think I know where a set of correct rims are.
I am not sure if it would pull a 5 bottom or not.  Would be neat though.
Adam
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 1:14am
I think when you get done with it I can have a Dodge to trade you!! LOL!!
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 7:43am
Believe it or not, that front step may be AC.  It is actually a support stand for AC cornheads when they were shipped from LaPorte, IN.  We used to have them laying around Dad's dealership by the dozens.  Some guys liked the wider base instead of the smaller step that was OAEM.  Also there were some One-Ninety's that did have the short profile five-rib tires like those shown.  FWIW.
Brian F(IL)
