HD11E turning with clutch only
Gargoyle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Topic: HD11E turning with clutch only
    Posted: 09 May 2014 at 6:40pm
As I'm fairly new to the dozer game, ok really new to the dozer game, how much turn should I expect from just the clutch? I don't really get much when driving on level ground with no load. I get more turn when going uphill or under load. Is that normal?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2014 at 8:48pm
sounds normal to me.  if you need to turn when not under load or turn sharp, use clutch and brake
Edited by CAL(KS) - 09 May 2014 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 3:58pm
My 7G responds that way, only issue I have is not much forgiveness when using brake to turn, is either on it or off with the power brake hydraulic application. Gotta be careful for tighter quarters and turns.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 4:02pm
Thanks for the input.. I had no experience to go on to judge how well this is working..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 4:30pm
I haven't gotten game on enough to adjust the brakes application pressure since I replaced my steering hydraulics pump, I suspect someone was trying to make up for a worn unit and tightened down pretty harsh, after the trans work is done will look to that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gargoyle Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 5:37pm
The previous owner of my machine had the right steering linkage tightened down so the clutch was always engage. They appear to be trying to correct a problem that the clutch was oil soaked due to a leak on the seal for the bevel gear.
I remedied all of that an put on new brake linings.. Steers nice and smooth on the right side. Left side brake linings are still to come.
