PISTON,RINGS,WRIST PINS &CLIPS
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: PISTON,RINGS,WRIST PINS &CLIPS
    Posted: 03 Mar 2010 at 7:50pm
HELLO
 WOULD ANYONE HAVE OR KNOW WHERE THERE IS A SET (6) OF PISTONS,RINGS,WRIST PINS AND CLIPS FOR A 185 DIESEL. I HAVE (6) NEW SLEEVES JUST NEED THE PISTONS.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 7:28pm
get in touch with BUDA ENGINES IN SHREVEPORT,LA talk to jim i bet he can fix you up ph 318-222-3348
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 7:49pm
The 185 has an Allis made 301, not a Buda engine.  Maybe you can call up an aftermarket supplier and see if any of them will sell you the piston and sleeve kits without the sleeves for a discount.  It's worth a try.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 10:24pm
hurst...i do appologise for the mistake on the ebgine mfg.i guess i had buda on the brain.i will ck with a few of the engine shops around here that do oilfield engine work...
