Simpicity Regent Stuck in Reverse
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Simpicity Regent Stuck in Reverse
    Posted: 07 May 2014 at 6:25pm
Anyone have an idea of why my mower suddenly got stuck in reverse? The shifter don't seem like it is catching on anything like it did before. It's a 5-speed.
Can't fix stupid
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2014 at 7:15pm
does it have a peerless700 it may have a broken shifterkey in side the trans very easy to work if there are mower racers around you they all have parts thats the trans they use most of those guys take the reverse gears out of the trans to lower the rotating mass and less to blow up at 40 mph
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2014 at 7:19pm
if it is apeerless transaxle it is about the same inside the grease is messy
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2014 at 9:20pm
Well I figured out that the lower casing is broken and has lots of moisture and corrosion inside the transaxle. So looks like I need a new transaxle. It is a peerless. What other mower were these used in? It's a 5-speed
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2014 at 10:04pm
Anyone have an axle?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2014 at 10:34am
later 76 78 ish johndeere108 i believe its 900- go to your local mower shop that does tecumseh and they can order you all the parts books
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2014 at 1:13pm
This mower is from the prolly the 90s
Can't fix stupid
