Ignition terminals
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: Ignition terminals
    Posted: 03 Mar 2010 at 4:24pm
I picked up an Indak ignition switch Part #7-01854 at Napa today to install on my 706D forklift.  I believe the AC 170 tractor & maybe others use this same switch.  My problem is I did not label my wires when I dis-assembled it and now I can't remember how to hook it back up.  The switch is marked with letters on the back, but I don't know what they stand for.  I am hoping that someone on here can tell me what these letters beside each terminal(5) mean:
S
B
R
A
I
Thanks.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 7:33pm
I would guess
Starter
Battery
R???
Accessory
Ignition
Like I said I am guessing, you could always use an ohmmeter to see what each terminal does when you turn the key
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 7:46pm
r for regulator?
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 8:05pm
that would make sense to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 10:41pm
The 854 indak is a crank start type switch. Here's what the letters mean:
S-  Solenoid
B- Battery
R- Regulator
A- Accessory
I- Ignition
Steve@B&B
