WC Front Crankshaft Pulley
dbrus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbrus Quote  Post ReplyReply Direct Link To This Post Topic: WC Front Crankshaft Pulley
    Posted: 03 Mar 2010 at 9:26am
I teach a Power Technology class at a high school in Iowa and I have a group of students working on rebuilding a 201 CI gas engine out of an old WC.  My question is what is the best way to remove the handcrank/crankshaft pulley off the front of the engine?  I tried to have one of my students use a 2 jaw gear puller, and he ended up cracking the pulley.  I felt like an idiot after that for setting the student up with the wrong tool for the job.  Does anyone sell these pulleys aftermarket or can I get one from a salvage yard easily?  Thanks for any input.
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 6:00pm
I cracked the first one i did too. I even used a bearing splitter and tbar puller, thought i was doing everything right. Last one i did i used a little propane torch and held it under the bottome for a couple minutes. It came off so easy i dont think i even needed the puller. Basically threaded the screw in by hand and it came off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 7:34pm
I took one off my parts tractor last weekend with a small prybar and a little brass hammer. it took longer to get the setscrew out than to remove the pulley. They are available as a reproduction for something like $180 I believe. Find a boneyard and go borrow one from a donor.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 7:37pm
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 8:18pm
 give us call 1-800-254-3116 we have some
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 10:32pm
UM, just for the record, I believe that there is a set screw, on top of a set screw holding that pully in place. Is it possible there is still a set screw holding things up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2010 at 7:14am
Lou, the WC's I have, have a long set screw with a jam nut on top.
