hd6b
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Topic: hd6b
    Posted: 02 May 2014 at 6:40pm
While adjusting wet clutch on dozer dropped a bolt and lockwasher in housing!!! What are my chances of finding it with a magnet and flashlight???????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2014 at 7:29pm
Just keep fishing - surprised what one can snag - might try putting something over magnet so it doesn't stick to the housing and just the bolt and washer .
 I have fished tools out of rear housing , parts out of dry clutch housings with magnets
GOOD LUCK
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2014 at 7:32pm
Thanks coke I think I'm going to need all the luck I can find
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2014 at 7:37pm
So.......how did the fishing go? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2014 at 8:47pm
found the bolt never found the lockwasher !!!!!!!!!!!!  hope I never do
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2014 at 10:03pm
I would think a lock washer in there would be pretty harmless. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 2:02pm
I'm sure hoping so
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 3:48pm
Will be in the clutch oil sump at some stage if not already there. not difficult to get it out of there with the sizable drain plugs AC use
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 3:55pm
My 7G has magnetic drain plugs, did these? If do will stay there until you pull the plug.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 4:23pm
They didnt put magnetic plugs in those engine clutch sumps Dave, but they used the same thread for the plug as on the powershift trans and most other drain plugs on the machines, so you can put a mag plug in if you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2014 at 8:36pm
thanks guys making me feel better
This page was generated in 0.127 seconds.
