What transmission fluid to use in AC forklift
ajdesmarais View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ajdesmarais Quote  Post ReplyReply Direct Link To This Post Topic: What transmission fluid to use in AC forklift
    Posted: 30 Apr 2014 at 11:50am
Hey, I've got an old 4000 lb Allis-Chalmers forklift where I work, the model is C-40, serial number is 172532. I need to refill the transmission fluid, but I'm not sure what to use. The gearbox is so dry I can't even tell what it has in it right now. Any advice would be appreciated, thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 12:05pm
http://www.minnpar.com/crawlertractorforkliftparts.asp
can try Minnpar or Herc-U-Lift  for info .
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2014 at 10:10pm
if its a power shift it should be atf
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
