616 Running hot
Tom6070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom6070 Quote  Post ReplyReply Direct Link To This Post Topic: 616 Running hot
    Posted: 29 Apr 2014 at 9:27pm
Hey Guys,
My 616 has a good running original Onan engine. It seems to be running a little hot. Backfires when shutting it off. Anybody have any ideas?
I plan on replacing the engine in a few years. Thanks, Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2014 at 9:40pm
Carbon buildup on the heads probably.Might have timing off slightly and cooling fins clogged up. HTH Tracy
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2014 at 6:36pm
mines done it since I bought it in 2000,i'm thinking carbon to but still have never had head off,maybe this year
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2014 at 12:10am
Back firing isn't really a running hot issue. Any little flake of carbon or oil residue buildup can cause this. A lean carb will mare it pop and backfire while lowering throttle or at shutdown. Btw, a lean carb will also make it run above normal temp.
Yea, I can fix that.....
This page was generated in 0.379 seconds.
