Exhaust manifold on an E combine? |
KurtDE
Joined: 19 Sep 2009 Location: Hilton New York Points: 83 |
Topic: Exhaust manifold on an E combine?Posted: 02 Mar 2010 at 7:06pm |
Is the exhaust manifold on the E the same as the 170 gas manifold? I am looking at the E motor to replace my 170 and the 170 needs an exhaust manifold. Kurt
DrAllis
Posted: 02 Mar 2010 at 9:00pm |
It'll work....good luck getting that 90 degree elbow unthreaded from it and installing the 170 pipe.
KurtDE
Posted: 03 Mar 2010 at 4:42am |
Thanks for the info Dr Allis.
wheelbilly
Posted: 03 Mar 2010 at 10:23am |
I used a hack saw to cut the elbow off flush with the manifold and then used a dremel tool with cutting disk to split the part of the elbow still inside. Used a chisel to force in a bit and then screwed it out.
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1289 |
Posted: 03 Mar 2010 at 10:44am |
I did the same a Wheelbilly.
