wanted IB parts
lukeWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lukeWI Quote  Post ReplyReply Direct Link To This Post Topic: wanted IB parts
    Posted: 02 Mar 2010 at 7:02pm
i am looking for anyone who has some Ib parts or has parted out an IB. i am needing a steering column, left fender, draw bar set up, choke and starter rod. thanks for any help, either send me a message or call me at 715-317-0017. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 9:02pm
luke, if you dont get any takers--- you can cut down a B steering column to make that, you can modify a WD fender to use on the IB, and the choke and starter rod can be made from round bar stock.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 9:11pm
luke,
Are you looking for the steering column tube, or the shaft with the worm on the end?
If you are looking for the shaft with the worm gear, I could measure the NOS one I have here for you. You would need to take a regular B shaft and cut a piece out of the middle and reweld it. It is hollow, so you should be able to put a rod inside to reinforce the joint area. If it is just the tube, they are easily made from some thinwall tubing.
Glenn
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 9:23pm
Roger VanCamp has some IB's being parted; ph 260-747-3455.  Fort Wayne, IN, near the airport.  Leave it ring a while as Rogers hearing isn't that great, and his pace is getting a little slower; sorta like someone else I know.  Herb
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 9:48pm
Luke I used 2 new fenders from stiener on my IB and they came out good. You need to flatten the forward lower boss to use the WD fender and then copy the flat block off plate from the old IB fender. Cal in Ct.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2010 at 11:40am
When I restored my IB, I purchased a couple WD fenders from Tony C. A little bit of alteration that my body man did, using the IB fenders as patterns, and I had a sweet lookin' set of IB fenders! I also made my starter rod and made the rest of the foot throttle linkage that was missing. That was a fun project though I must say...
