1971 AC HD6G wet clutch?
ericm123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ericm123 Quote  Post ReplyReply Direct Link To This Post Topic: 1971 AC HD6G wet clutch?
    Posted: 27 Apr 2014 at 5:00pm
I'm looking to buy a 1971 6G SN 23442. I have to travel a bit in order to even see this unit, and the seller doesn't know if it has wet or dry master and steering clutches. Does any one know if the wet clutches were standard equipment after a certain date, or all the "G" models? I know that "E"'s after SN 14474 had wet clutches, but I hate to assume that all "G"'s had them. Thanks a lot,
AusHD6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AusHD6 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2014 at 5:45pm
Hey Eric
All HD6G's have dry steering clutches, only the HD7G's & GB's had wet steering clutches as standard. I'm not sure about the master clutch though, all of the 6000 powered G's that I've seen (which isn't a lot) had a wet master clutch.
Cheers AusHD6
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2014 at 4:43am
I dismantled 6 HD6G and the was dry master cluch and dry stering cluch but I know some HD6G too have some wet too you just need to check by the inspection cover plate
Post Options Post Options   Thanks (0) Thanks(0)   Quote ericm123 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2014 at 8:14am
Thanks for the replies. I guess I'll find out when I get to see the machine. My thoughts are that the wet clutch is more reliable and requires less maintenance (i.e., adjusting, replacing, etc.) than the dry clutch; as long as you have good, clean oil and screens and filters, the wet set up is better. Is that just my opinion or pretty much a consensus? My 1946 cat had a wet clutch and it worked flawlessly for a decade. Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2014 at 2:03pm
Yes the  wet master cluch and stering cluch are better and 1971 must be wet one.
This page was generated in 0.445 seconds.
