1974 200
ChadB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChadB Quote  Post ReplyReply Direct Link To This Post Topic: 1974 200
    Posted: 02 Mar 2010 at 6:37am
I have a 74 200.  I've had it several years and every sense I have owned it it has a pretty severe lope at idle.  Once the rpm reaches 1200 to 1500 the lope goes away, and also it will not lope if it under load (ie pulling equipment),  Also it is very noticeable in road gear at low rpm < 1500 rpm.  Could this be a problem with the injector pump or the injectors themselves.  I have been told that this is common with the Allis tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 7:32am
Sounds like the governor ring in the injection pump to me.  Not to bad of a job to get rebuild.  Andy
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 8:24am
My 75 model 200 will lope a bit just after a cold start but as soon as it warms up it goes away. I kinda like the sound!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChadB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 8:59am
Mine also does it worse when cold, and then as it warms lessons the lope to some degree.  I just tell people I have an oversize cam in it.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 10:21am
speed up the idle.
This page was generated in 0.680 seconds.
